take out the plug
undo and remove rear cover over element
there should be a thermostat with a red reset button, push it gently and it may go click. If yes you have reset it and it should now heat.
If it blows again quickly then we need to figure out why it overheats
electrofix wrote:take out the plug
Yes lad!!!
Thanks so much, I found the button and it worked first time. You’ve saved me £200 🙂
