Beko DTGC8001W Home › Forums › Trade Technical & Spare Parts Forums › Beko DTGC8001W This topic has 5 replies, 2 voices, and was last updated 4 years, 7 months ago by delta01. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts August 26, 2021 at 3:02 pm #99976 delta01Participant Recently replaced heater assembly and tested it seemed ok having sold it the toc tripped and there was water all over the heater compartment any suggestions please thanks john August 26, 2021 at 7:55 pm #478729 electrofixModerator the water in the duct is probably because there was no heat but you can check the pump and ducts to make sure it drains I would swop out the front TOC. you can check it if you like its rated 12K at 25 degrees Dave August 27, 2021 at 10:30 am #478730 delta01Participant thank v much Dave where is the front toc located please thanks john August 27, 2021 at 8:40 pm #478731 electrofixModerator August 27, 2021 at 8:48 pm #478732 electrofixModerator have emailed you the manual Dave November 19, 2021 at 5:19 pm #478733 delta01Participant sorry for v late response i tried a new thermistor but it still failed i gave up and scrapped it thanks for your input john Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
