Beko dtlce80021w too hot
  • #103342
    deltra
    Hi,all,beko condenser dryer dtlce80021w getting too hot!!! Anyone know what max temp is on this machine,this got to 96c before I switched it off,is this controlled by ntc,if so where located this is stuck up on a shelf not easy to access ,would like to go prepared ,and have all I need for one repair:D thanks
    #492782
    well the resettable stat goes out at 160 degrees so its designed to get very hot
    deltra
    Beko seem to say max temp 75c:eek:
    #492784
    the tech manual seems to give those sort of temps to the heat pump version. gives no data for the heated one
    deltra
    Heater doesn’t trip,it does get untouchable,not sure where to go with this,maybe change ntc anyway.just really need some idea what the temp can actually be to still be safe.
    #492786
    have emailed you the service info in case it helps
    deltra
    Thanks Dave got it sorted,looks like temp is very hot:D
