Hi. I have a Beko DV 5531 and the main oven is not heating. The fan is working and light. From reading similar posts I assume the element needs replaced. Firstly is this expensive and secondly would it be an easy job to do myself and where could I source the part. I live in Ayr, Scotland.
It would certainly point to the element Cally and won’t be an overly costly repair.
It depends on your own capabilty and confidence to be honest as far as DIY replacement goes. Safety first so if you’re unsure, I would recommend an engineer, check Repairs@ for one 🙂
If you decide to go in yourself, power off at all times please :zap:
