I have a Beko DV555 Double oven cooker purchased in Dec 2006. Whilst in use the main oven and clock/timer stopped working.
No previous problems experienced.
The top oven still functions (thankfully) as do the “rings”.
Is there a solution to the problem?
Can this be repaired by me with obtainable parts? 🙁
There is a small safty cut out in the back of the oven on the live feed from the terminal block which has probably failed causing this problem. Quite common. Easy enough fix, just test cut out for continuity and replace if O/C. Remember to disconnect mains of course . Cheap enough fix if you get someone in though.
