BEKO DVC 565 OVEN DIGITAL DISPLAY NOT WORKING
Home Forums Public Support Forums Help And Support Cooker And Oven Forum BEKO DVC 565 OVEN DIGITAL DISPLAY NOT WORKING
  • #69021
    teresagreen
    I HAVE A BEKO DVC 565 COOKER AND THE DIGITAL DISPLAY IS NOT WORKING,WHICH MEANS I CANT PUT THE BOTTOM OVEN ON.IS THERE ANY PART I CAN ORDER MYSELF?oops caps sorry 😳
    #373451
    captaincaveman1
    Re: BEKO DVC 565 OVEN DIGITAL DISPLAY NOT WORKING
    most likely the white cut out stat at the rear of the cavity on the right hand side (if viewing from the back) has failed
    #373452
    beezer123
    Hiya
    I realise this thread is quite old now but wondered if replacing the cut out stat worked? I have the same problem, oven stopped working the other night and realised the digital timer had stopped working. Just want to make sure its worth trying to replace the stat or timer display before I invest time and money into it, if not I will just buy another cooker. Any help/advice would be very much appreciated. Thanks 🙂
