Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Beko DVC6631 oven problem
- This topic has 6 replies, 4 voices, and was last updated 12 years, 3 months ago by
itisme.
January 9, 2014 at 8:00 pm #78944
itisme
ParticipantHello folks!
I’am wondering if any of you kind folk could solve a problem for me?
I have a Beko DVC 6631 cooker,however there seems to a problem with the oven.Being the type of fella that like to fiddle with things…I thought I’d fix it myself.So off to Ebay I went armed with the model number and ordered an element.Not quite the quick fix that I thought it would be! It seems that the problem was not the element as I had assumed (The missus said the oven had stopped heating 😆 )
There seems to be NOTHING happening in the oven department at all,no light,no fan and no heat despite fitting the new element)
I did swap the selector switch (I think that’s what it’s called..the brown plastic thing behind the knob)with the grill selector,and it worked on the grill…so that’s that ruled out as a problem.
Any ideas what else I can check,test or change to solve the problem?
All ideas/suggestions appreciated.January 9, 2014 at 8:07 pm #407441Andy jones
ParticipantRe: Beko DVC6631 oven problem
There’s a toc controlling the oven. That’s almost certainly the problem
January 9, 2014 at 8:18 pm #407442itisme
Hi Andy,thanks for the speedy reply.What is a Toc,and can I repair it?…or do I replace it?
January 9, 2014 at 8:29 pm #407443kwatt
KeymasterRe: Beko DVC6631 oven problem
This..
http://shop.ukwhitegoods.co.uk/21011054 … thermostat
That’s a problem with any number of Ebay sellers and some others, not enough information. As well as taking the time to diagnose from the get go. 😉
Don’t beat yourself up over it though, loads of people do the same or similar.
January 9, 2014 at 8:40 pm #407444SAMURI
Have you set a time on the oven timer?
If the Timer is just displaying zero and no time is set the main oven will not work.
If you set a time and it is not working it will be the thermal overload cut out NTC faulty.
On Beko ovens this is normally a long wire with a thermal cut out in it runs from the switch to the element and clips to the back of the oven cavity.
On your model it may have a separate cut out attached to the oven cavity .
If the oven was making a noise but no heat before you replaced the element then you have not set a time on the clock.
Bob
January 9, 2014 at 8:52 pm #407445itisme
Thank you all very much for taking the time to reply. 😀
I’am going to try the clock first,then if that doesn’t cure the problem I’ll try the thermostat.
I’ll keep you posted. 8)
January 13, 2014 at 9:30 pm #407446SAMURI
No update was it the clock not set 😀
Bob
