Beko DW D3241FW advances thru prog’
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko DW D3241FW advances thru prog’
  • #13706
    Seamy
    Gotta go on Fri’ to look at a Beko D’Washer D3421FW that customer says advances quickly through the programme, she always uses #2 prog’ 65c, has repoeted that she hears it pumping out at start-up then filling, then washing but moves through programme cycle very fast . I suspect possible faulty thermostat causing it to move through heating cycle, any other ideas would be appreciated.
    #156204
    Re: Beko DW D3241FW advances thru prog’
    If it washes for a while, then sets off round the rest of the programme it’s the NTC at fault. P/no BE1884400100 – £5.50 from SEME.
    This could be a filling fault on this model.
    The left hand side filling chamber has a water wheel counter with tacho magnet attachment, if the wheel does not register within the parameters it aborts programme.
    The side chamber removes easily and a couple of minutes under a running tap will clear the blockages. The blockages are not always easy to see, ie not food or powder residue, but clear slimey/fungus growth, in the vicinity of the wheel and the small compartments near it.
    Kevin
    #156206
    Seamy
    Where is this NTC located on the machine, i’ve looked on Connections Mediator & don’t see it listed as spare part.
    #156207
    Down on the sump IIRC.
    Seamy
    Cheers, your on the ball today, thank you..
