Hi Guys Has anyone actually tried putting a Beko electronic d/w in test mode. The one I posted about at Christmas would only activate the wash & drain pump for 2 secs then nothing. Since then I found my mate had a slimline Beko d/w which did exactly the same in test mode. Now some of the controls are on top of the door like a built in d/w so I have removed the lid & tried the test mode with door closed & open. When the start button & prog selection buttons are held for 3 secs the prog lights do all light as suggested & then when the start button is pressed all it will do is a very short test with wash & drain pump but thats it. Any suggestions anyone . Thanks Mack.
Check the fill circuit, if its not doing anything there, perhaps thats where the fault lies.
They are very problematic on filling, they should count 4 litres of water via a flowmeter before progressing to wash. Check water valve, flowmeter, cabling to flowmeter & water valves as these fine wires are prone to breaking in the loom.
