BEKO DW4310S won’t run full cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum BEKO DW4310S won’t run full cycle
  • #94191
    Steven-DIY
    Hi all,
    first post…
    I am having trouble with my BEKO dwd4310s dishwasher, all program selection results in
    1 drain pump comes on
    2 dishwasher fills with water
    3 wash cycle runs for about 10 minutes
    4 wash cycle stops and drain pump emptys water
    5 red light (end light) illuminates indicating cycle is finished
    I need to know if the PCB module may be faulty and if buying a new one might resolve the issue?
    I did ring Beko and spoke with a cuy who suggested I check all connections and hoses, pump. I did all that, also did the tilt it 45 degrees trick to no avail, I also unplugged it from mains for 3 hours then switched it cack on while holding start/stop button for 15 seconds as directed by Beko guy then put it on wash 4 (intensive)
    It still ran only for 10 minutes as shown in the steps above.
    Any thoughts are appreciated.
    Steven
    #456672
    Re: BEKO DW4310S won’t run full cycle
    will it run the pre wash programme ?
