Beko DW601 no power after power outage
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DW601 no power after power outage
  • #97444
    Labeline
    We have a Beko DW601 Dishwasher which until yesterday was working fine with no faults or issues apparent. The machine was running a wash cycle when we had a power outage. It was still turned on when the power came back on a couple of hours later but when we checked it the lights had gone out and it no longer works. I know there is no thermal fuse in these. Would a power outage or more likely the sudden return of power while it was running have burned something out? I have looked at the wiring and it all appears to be intact with no burning or breakages.
    #467796
    its unlikely any wires will have burnt out
    check the socket its plugged into if that is ok it will probably be a board problem as power surges can take out electronic circuits
    Labeline
    Thanks. That’s what I feared. The socket is fine. It’s 8 years old so looks like it’s time for a new one.
    #467798
    Labeline
    Is there any way to test it to confirm that’s what it is? Being on lock down is going to make getting a replacement awkward for now.
    #467799
    only if you have technical equipment and knowledge
    an engineer would have to check if the power was getting to the control board and if yes if the low voltage was present on the board to supply the components
    Labeline
    Thanks. New one it is then! Appreciated.
