Beko DW602 Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DW602 Dishwasher
  • #89313
    jamesenewton
    I have a Beko Dishwasher that fills with a small amount of water that barely covers the bottom of the dishwasher. When I turn it on it drains, fills slightly and then nothing happens for several minutes. It then drains again and fills again and continues to do this. I have checked the overflow float which is fine and checked most components with a multimeter. There are no leaks or water in the tray underneath. I have already replaced the water inlet valve and the thermistor due to it not working properly a few weeks ago. Can anyone please help? I don’t want to waste money on parts that are not necessary nor on someone to come out or even worse to replace it altogether.
    #440977
    Re: Beko DW602 Dishwasher
    You’ll only get about that amount of water in it, that sounds correct.
    If it fills then does nothing, do you mean there’s no wash action at all? And, have you tried it on a rinse only?
    jamesenewton
    Hi thanks for your reply,
    The amount of water is just around the filter in the middle and not over the whole base. I have taken the sides off and I can see the water filling in the tank. I can leave it for an hour or longer and in that time, a bit of water comes in after a few minutes it drains out and it repeats this without any water going through the arms. I have tried resetting and different programmes and even added additional water. I didn’t know if it was the capacitor but now wondering if it’s the water flow meter.
    #440979
    captaincaveman1
    Could well be the watercounter at fault here its accessed by removing the left side panel and the internal fill hose from the water valve connects to the bottom of it .
    #440980
    jamesenewton
    Thanks,
    Would that be the same as the water flow meter?
    http://www.bekospares.co.uk/water-flow- … id=2195206
    #440981
    Lawrence
    power off and plug out ,remove the outer door panel look at where the cables go under the door at the bottom ,you are looking for 2 thin purple wires one of them will be broken.
    #440982
    jamesenewton
    Thanks, do you mean remove the cupboard door panel as it’s integrated?
    #440983
    Seamy
    Most likely fine wires broken in loom, as Lawrence said previously, wires to Thermistor or Flowmeter likely are broken. Appliance should count 4 litres of water before powering up wash pump, if it doesn’t get signal from flowmeter then it goes to finish program’, emptys.
    #440984
    jamesenewton
    I will take a look. Could it not be the pcb in the water flow meter? Thanks
    #440985
    captaincaveman1
    I’d replace the watercounter/flowmeter first but let us know how you fare once sorted
    #440986
    jamesenewton
    Does anyone know if the part SKU: 1760900100 would work. I assume it would as it says for DW600. The part number is slightly different my part is 176090xx00
    #440987
    Yep, it’s this one:
    https://shop.ukwhitegoods.co.uk/1729900 … flow-meter
    jamesenewton
    Just fitted the new flow meter with little improvement. At first it filled with more water but the water never got hot and it hasn’t been pumped through the arms. I have tried different settings and it now seems to be as bad as previously. What else can I try or should I bite the bullet and either get someone to look at it or buy a new one, it seems like a waste of money on the parts I have replaced so far.
