Beko DW602 Dishwasher Faulty
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DW602 Dishwasher Faulty
  • #94951
    DeeDub
    My Beko DW602 integrated dishwasher stopped working. I ran the diagnostics program and it came back with the P2 green light flashing.
    After searching on this site I found that this meant the water inlet valve or water flow meter was broken.
    I’ve replaced both but it is still not working and the P2 light is still flashing.
    Can anyone please help or offer advice as it’s driving me nuts.
    #458917
    does it take water in at all ?
    DeeDub
    It does let water in and drains ok when doing the diagnostic test. But it doesn’t do anything now, the P2 light just flashes.
    #458919
    that’s a bit odd
    could understand if it took no water in and the valve was faulty
    could also understand if it took a bit in the aborted due to faulty flow meter
    but to only fill on diagnostics that a bit odd
    sound like it may be a board fault
    DeeDub
    Thanks Dave.
    It does seem odd to me as well.
    I thought the system might need resetting after the repairs so I disconnected the motherboard. Reconnected it and then started it again, but this didn’t work either.
    Frustrating…
    #458921
    how old is this unit ?
    information I can see puts it over 10 years old
    DeeDub
    We bought it new about 5-6 years ago.
    #458923
    normally the first 2 digits of your serial no are the year ie 14-***** 2014
    take it now you cant even run diagnostics or does that still work ?
    DeeDub
    The serial number starts with a 12 so 2012.
    The diagnostics does run, but only once I’ve disconnected and reconnected the motherboard.
