Beko dw603
  • #91359
    kaibart
    So I went to this beko dw603 dishwasher yesterday that had water in the base dried the water out removed side panels and front panel to check for leaks run on a quick and clean programme which takes a hour stayed all the way through the cycle to check for leaks could not find anything. I’ve checked both spray arm they are fine and its not overfilling either I convinced there is a leak and I can’t find it. Anyone had this before and found the problem, any help appreciate kai.
    #447838
    BURNIE
    Re: Beko dw603
    hose blocked with grease etc air break on right side to sump. remove clean out and refit all will be well.
    #447839
    kaibart
    Re: Beko dw603
    It’s all clear
    #447840
    adv
    Re: Beko dw603
    did you fix this ? as i have same problem ?
    #447841
    kaibart
    Re: Beko dw603
    Didn’t get called back to it thou worth checking the air breaks are tight thou I’ve had 1leak from there
    #447842
    adv
    Re: Beko dw603
    this one is weird tho . went to it was water in base pump running all time .. then reset it .. it started to fill straight away , doesnt pump come on for few times then starts to fill . ? customer called back done same again mmm . couldnt see a leak ..
    #447843
    aqualectric
    Re: Beko dw603
    I had one doing this on fill. Filled, stopped for a minute or so and then refilled again; on, off, on, off, until it flooded the base. It was as if the module got 30 seconds into fill then reset and started again. Tried module and flowmeter in fact metered everything and all OK. No leaks anywhere. It was doing my head in. Turned out to be broken door wires. I’ve since had several Beko’s with door wire issues – all with slightly different problems but all were intermittent stop start faults.
    Who’da thunk?
    Steve.
    #447844
    adv
    Re: Beko dw603
    o right it could be as i kept trying to reset prog to drain it .. but wouldnt . then after opening shutting and trying a few times pump kicked in .. only just over two years old , thought the days of broken wires down door loom were long over } will need to take it apart suppose (.
