Beko dw603 dishwasher not filling with water!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko dw603 dishwasher not filling with water!
  • #96446
    Indiola
    My Beko DW603 dishwasher has just stopped filling with water. I have cleaned all the filters out. Checked inlet pipe! Anyone got any ideas? Only 2 years old.
    #463417
    well its starts getting technical from here on in
    check base for water and check overflow switch operation
    check inlet valve coil
    andyjawa
    Fairly common that the fill matrix behind the left hand side panel gets a limescale blockage around the internal, I think, blue comma shaped insert you should see through the semi transparent unit near the top. Remove and catch any water with a towel as being removed, turn it upside down and try to blow down where the valve pipe`s nozzle was fitted, any restriction is the cause. The cure is to buy a bottle of Kilrock descaler and pour SOME of it down that nozzle with a dry cloth or wear rubber gloves and if you look very closely you should see it fizzing = limescale present. leave in a w/up bowl for 5 minutes, drain out the Kilrock, clean nozzle of acid residue and blow rhtough to test. Be very careful of Kilrock: eyes mouth & fingers, beware, nasty stuff but this is how I clean out limescale from these matrixs.
