Beko DW603 integrated DW
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DW603 integrated DW
  • #97478
    Haydn Williams
    Hi Guys
    Looking for advice. Got a leak coming from bottom of the washer and suspect the lower door seal needs replacing. Does anyone know if I’ll need to take the door off to do this task of can it be done with the door in place.
    Cheers
    Haydn
    #467953
    have a close look at the seal. dont assume its the lower seal as it can leak half way up the door and drip down
    check the door closes properly. clean anywhere the seal touches the door. Check all the revolving bars for blockages. if some are blocked then the other ones become more powerful and can push seals. make sure all basket wheels are present and the bars can revolve freely
    also check water level when full as overfils can cause leaks
    Simon46
    Also check the lower spray arm isn’t split along its seamweld as it will spray sideways under the door.
