Beko DW603 Leak
  • #89464
    chris4195
    Hi I recently purchased an integrated Beko DW603 from AO which has had a small leak ever since I first tested it in July.
    The leak starts after 20 minutes of a cycle and is a slow drip from the bottom of the door – all seals appear to be good.
    The plumber has been out and confirmed it is level and plumbed in correctly.
    I have had a Beko engineer out who could not see any fault and suggested I go back to AO as it is likely it was damaged in transit (no damage was visible to the packaging when delivered ).
    As I have only ever tested it I have never ran it with any detergents/salts – could this have anything to do with the leak?
    #441452
    Re: Beko DW603 Leak
    We had another similar one like this here a while back, not sure if it was a Beko or not though.
    With integrated when that happens it will invariably be that something isn’t quite square and level and the cabinet and/or door is being twisted very slightly so it doesn’t seal just quite correctly.
    Detergent etc will have no effect on that.
