Beko DW603 No lights and no action!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DW603 No lights and no action!
  • #87124
    Rexy7
    Hi All,
    Merry Xmas everyone! Please Help!
    Two days before chrimbo and 2 months out of warranty our dishwasher packs up!!
    Turned on and started ok but when i returned at the end of the day i opened the door and not everything was clean and now i have no display and no action!
    I have tested fuse, main on/off switch, door switch, program/timer/reset switches, also getting 240v at mains coming in and from output on filter. Haven’t got a circuit diagram to fault find any further but guessing that the pcb has gone?
    Checked over PCB and there is no obvious burn outs…
    Any ideas or help would be much appreciated.
    Thanks,
    Alan
    #434013
    Re: Beko DW603 No lights and no action!
    just checking how you checked the power ( dont know you level of knowledge)
    have you got a live and neutral coming in ?
    then if you have live and neutral at the board then its likely to be that
    Rexy7
    Hi Dave,
    Thanks for your reply…
    I have 240v at the board and also from the door switch to the board so is looking like the PCB. I didn’t check the neutral so maybe i will check that for continuity tomorrow and also lift the float switch to see if the drain pump comes on..
    Pretty sure it is the PCB 🙁
    Any idea where i can get a PCB for this model of dishwasher?
    Thanks,
    Alan
    #434015
    email the site shop
    Rexy7
    Hi All,
    Just thought i would give a quick update on my issue..
    So i finally had a chance today to take another look and on closer inspection the transformer on the PCB has blown.. Thought i might be able to source one as they are roughly £4-5 instead of paying £50 for a new PCB however so far i haven’t been able to identify the faulty component.
    Will try again tomorrow and if no luck will order the new PCB.
    Alan
