Beko DW603
Viewing 15 posts - 1 through 15 (of 21 total)
  • #91130
    jrm09
    Hi everyone a noobie but handy with a driver and a (photocopier tech).
    Above model approx 2 years old and now washes ok but leaves dishes cold and wet so suspect thermostat or element is this an easy job or can I do a diagnostic check first 😥 cheers
    #447163
    Re: Beko DW603
    Almost for sure the element, it uses this one:
    https://shop.ukwhitegoods.co.uk/1888130 … ng-element
    Continuity testing it is the only way to be sure.
    jrm09
    Re: Beko DW603
    Thanks for.Easy to get at? and is it top right ?
    #447165
    Re: Beko DW603
    Uhm yes and no, easy enough to do but it’s underneath… most of the working are.
    jrm09
    Re: Beko DW603
    Thanks for that will get to it this weekend, has anyone tried repairing the heater?
    #447167
    jrm09
    Re: Beko DW603
    Hi removed heater from DW603 got 29ohms across terminals, does that mean its ok and if so why have I no hot water and apparently no fault code?
    #447168
    jrm09
    Re: Beko DW603
    ok removed heater flow and measured approx 30ohms on terminals also removed ntc 90ohms cold run under hot water 25-30ohms, still no heat any other ides ‘??
    #447169
    jrm09
    Re: Beko DW603
    when switched on and running get 240v across brown live to heater and 28v to neutral.
    Does this mean heater gubbed even thoughnI am getting 30ohms across terminals?
    #447170
    Re: Beko DW603
    I have no clue how you’re measuring that but, using live mains is a very bad and dangerous practice that we cannot condone on here or someone will end up killing themselves!
    There’s no call to do it with mains power at all.
    Explained here: http://www.wikihow.com/Test-a-Heating-Element
    But that open of the stat on it open and, it’s in technical terminology, knackered.
    jrm09
    Re: Beko DW603
    I used a fluke multi meter and am experienced photo copier technician dealing with mains faults on a regular basis so know what I am doing. But I am confused by your reply, what stat? are you saying the nts is knackered?
    #447172
    Re: Beko DW603
    Yes, if memory serves that safety stat is a one shot one so, if it goes, new element.
    jrm09
    Re: Beko DW603
    sorry still confused I thought the nts monitered the temp and you say new element do you mean heater or nts?
    #447174
    Re: Beko DW603
    There is a safety stat built into the heater itself or should be, then another thermistor or thermostat depending on the setup to control operating temperature.
    jrm09
    Re: Beko DW603
    went to a mates house with same model tested heater and nts both the same readings as mine, if thermistat in heater open will I still get 30ohms from element? And if so how to check thermostat in heater
    #447176
    Re: Beko DW603
    From this, just like us, you’ll need to work it out…
