Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › beko dwd 4310w tripping rcd
- This topic has 11 replies, 3 voices, and was last updated 12 years, 11 months ago by
slyp98.
April 26, 2013 at 5:43 pm #75214
slyp98
Participanthi guys , have this dishwasher , about 10 mins into the program it trips rcd , unplug the heater element all is fine , replaced element , no change still tripping, no water leaking anywhere ?? any ideas
April 26, 2013 at 5:57 pm #394234Specialist01269
ParticipantRe: beko dwd 4310w tripping rcd
What does your Megger tell you ?.
April 26, 2013 at 7:41 pm #394235slyp98
megger is away for calibration !!
April 26, 2013 at 8:32 pm #394236Specialist01269
Always happens: Send the Megger for calibration, you can guarantee a pig of a fault where your going to need it 😆
April 26, 2013 at 9:09 pm #394237slyp98
i dropped it from about 4 feet high , some of the functions are not working i hope it can be sorted 250 quid worth only have it a year
April 26, 2013 at 9:57 pm #394238subs
Neutral wire from heater broken in door?
April 27, 2013 at 2:00 pm #394239slyp98
quite poss , gonna take it down on monday an check continuity
May 6, 2013 at 7:15 pm #394240slyp98
ok this thing is buggin me , checked motor ,heater, thermistor all ok , i put this on a 35 degree wash , all ok hits 35 , 38 ,39 trips rcd reset rcd works again for 60 second trips again , how can the ntc trip the rcd
May 6, 2013 at 7:26 pm #394241Specialist01269
The NTC can’t trip the RCD, it’s a Solid State sensor & only works on low voltage. What made you come to the conclusion that it was the NTC ?
May 7, 2013 at 8:31 am #394242slyp98
i didnt think it was, just frustrated that the temp is creeping up twoards 40 degrees on a 35 wash s’all ,
May 7, 2013 at 1:10 pm #394243Specialist01269
slyp98 wrote: how can the ntc trip the rcd
I was replying to / querying this bit of your post, which seems to say that you think the NTC is causing it to trip.
Did you check the wiring in the door ? it may not be anything to do with the actual temperature it’s getting to.
May 7, 2013 at 4:30 pm #394244slyp98
yeah ,ive tried all the wiring , components , switches etc , i only have my mulimeter though i cant check insulation
