Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › beko DWD4310
- This topic has 3 replies, 3 voices, and was last updated 16 years, 5 months ago by
OLLIE2806.
October 16, 2009 at 7:44 am #49353
OLLIE2806
ParticipantHi guys,
no matter what prog you select (be it 1,2,3 or 4), press start – the circ pump cuts straight in and sounds really rough like a kind of grinding noise, it does look as if its been leaking too, What would cause it to cut in like that? the pcp?
Thanks in advance
OllieOctober 16, 2009 at 7:52 am #299652bazza500
ParticipantRe: beko DWD4310
Are you sure it’s the circ pump and not the drain pump you are hearing?
If it’s leaking it would fill the base, make the overflow switch and run the drain pump continuously.October 16, 2009 at 7:57 am #299653OLLIE2806
its definately the circ pump, i’ve got the base off and can feel the circ pump vibrating whilst the noise is happening (i’ve also manually activated the anti flood and then the drain pump cuts in fine). Also when i say leaking i mean just a build up of gunk on the bottom of the housing not like a streaming leak.
October 16, 2009 at 6:20 pm #299654TheSpinDoctor
This may help you. In particular the paragraph titled Functional Test.
Softening adjustment:
In order to enter the softening adjusting mode, select the knop position of 1 while the DW is out of energy (on/off is shut) then
press the start button and energize the DW and keep pressing on the button for 3 seconds, after this DW enters the softening
adjusting mode. The adjusted softening level shown by the program follow up indicators for 2 seconds after entering the mode
Softening level should be decreased or increased by turning the knop to the positions of 2, 3 4.The softening adjusting
• For the 1st level select program 1 (pre wash program) (regenerates for every 200 lt water inlet). Washing indicator blinks.
• For the 2nd level select program 2 (regenerates for every 60 lt water inlet). End indicator blinks
• For the 3rd level select program 3 (regenerates for every 40 lt water inlet). Both indicators blink.
• For the 4th level select program 4 (regenerates for every 20 lt water inlet).Program follpwing indicators are off.
After selecting the required level of softening, save the selected level to the memory by pressing the start button and exit the level
adjusting mode.
At the regeneration step of the DW the salty water passing through the salt and regeneration units of the softener should be removed
from the stainless steel parts of the machine.
In the case of a need for a regeneration process at the end of the program, regeneration process should be done by energizing the
regeneration valve after finishing the last draining process of the last hot rinsing step Wait for 10 minutes after regeneration and
remove the salty water from the regeneration unit by taking 2,2 lt watier inside.
Waiting step after regeneration is counted as the time of waiting of the drying time.
In the case of energy interruption at the drying step, the program is ended normally. But in the case of energy interruption occurring
after the regeneration process, the program is not ended and resin washing step is done.Functional test
In order to enter the functional test mode (short program mode), select the knop position of 2 while the DW is out of energy (on/off
is shut) then press the start button and energize the DW and keep pressing on the button for 3 seconds.
All of the indicators turns on for 2 seconds after entering the short program mode.
Program following indicators blink if there exist any fault.
After entering the short program mode, press “start” button and begin for the short program. Short program follows the steps below.1. Draining (15 seconds)
2. Water inlet (4.4 lt)
3. Water circulation , regeneration (60 sn),
4. Detergent (60 sn), heating (to 65° C) .
5. After reaching 65° , stops heating and water circulation. The water inside is discharged for 30 seconds. Waits for
pressing the start button.
Short program mode will be finishedIn the case of any fault formation, the fault is shown by the program following indicators. Showing is as below:
All program follow indicators are off No fault
Washing indicator is on Water inlet or water counter is faulty
End indicator is on NTC is faulty
Both indicators are on Heater is faultyAll of the indicators blink after the functional test finishes in the case of no fault occurred
