Where is the pressure switch on these machines?
It drains but won’t fill.
Fill solenoid works OK, letting water in nicely when I operate it with my test lead.
Replaced PCB – made no difference.
Replaced flow meter – made no difference.
Anyone got any info, please?
Thanks,
Pigpen.
Overflow switch or warped polystyrene float are the most likely things to be causing the problem, have had lots of Beko’s like that. Otherwise cable connections onto board or flowmeter.
