Hello, I have leaks from two places in my Beko dishwasher 1) below the front door: I have replaced both upper and lower seal but it is still leaking. Could it be the detergent dispenser? or something else? 2) trickle of water from fan suction pipe. This grey flat plastic tube has a flexible pipe attached at lowest point which connects to the sump. On examination the flex pipe was blocked with crud but I have now unblocked it and have checked free passage for water to sump. However it has made no difference: The leak actually comes out of the large exposed aperture above right of the flex pipe union. I can’t work out how water can be entering the fan suction tube and why it is not simply running down into sump rather than coming out of aperture. Can anyone advise on above two leaks please? Thanks.
