beko dwd4311w stuck at end of wash
Home Forums Public Support Forums Help And Support Dishwasher Help Forum beko dwd4311w stuck at end of wash
  • #98502
    0ninjaef0
    I have had this unit for about 5 years. It degraded wash performance so I replaced arms, tubes, pipes inside the cabinet. Still no joy. So I took it in the garage, opened it up, and found the pump impeller blocked, pipes blocked, terrible. Removed them and cleaned them, then reassembled and placed back into the kitchen. Unit back to new in terms of cleaning performance. However…
    Now the wash cycle gets stuck at the end of Wash (there are 4 leds on the front panel: On, Wash, Dry, End). At the end of the wash, right before drying, when the pump comes on to remove all the water, well … the pump stays on and never shuts down. Only a power-off shuts it up. Power on again and the pump comes on again … until I power off.
    I’m wondering if there is some kind of float or something that I might of knocked or mishandled. I’m guessing the unit has some way of detecting if water is in the sump ?? Anyone have an idea and ideally – pics please???
    #472641
    0ninjaef0
    SOLVED
    It was the flood float. The mounting clips on the base of the unit had broke , the float was not level, the system thought water was in the bottom tray (flood) so was trying to pump the water out.
    Just need to find where I can buy the clips to mount it:
