I have tried this machine on rinse & hold, it will fill wash and then when it comes to drain the red end led comes on and no drain.
If I try and cancel (hold start/cancel button)pump still does not run, in fact nothing happens.
The only way I can get it to drain is if I lift the float switch in the base.
Any help suggestions much appreciated
Bernie
Re: Beko DWD5411 Dishwasher drain pump not running
I know you said it pumps if you lift the float switch but take the cover off that float switch to make sure its not burnt out… has happened to me in the past and pops the pcb in the process.
