BEKO DWD5411W dishwasher blocked?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum BEKO DWD5411W dishwasher blocked?
  • #94459
    whambam
    Hi guys
    i think my Beko dwd5411w dishwasher is blocked and won’t drain as i removed the filter and gave it a clean as well as removing most of the pooling water but it seems there is still a blockage
    how do i best approach this?
    Ive attached photos as its easier to see than explain
    thanks to anyone for any help!
    #457418
    Re: BEKO DWD5411W dishwasher blocked?
    does the drain pump run ?
    Seamy
    There will always be a little water in this sump area, there may however be a leak to base if its pumping continuously, the float switch in base may be activated.
    If however the pump doesn’t run its maybe blocked, piece of glass, food debris etc..
