Beko DWD8650 X
  • #64576
    Toni
    This dishwasher is completely dead, No lights etc
    Have check all the obvious, fuse, mains filter etc
    Power gets to the module, the on/off switch is ok
    The display pcb seems to get power to it, but no lights on it
    I suspect the module but would like to know if anyone else has had this before, before I order part
    Toni
    #357445
    Seamy
    Re: Beko DWD8650 X
    I’ve had problems with overflow switch bad connection on all of these Beko D’washers causing strange faults. If not that then change display p.c.b, lucky that Beko parts are dirt cheap.
    #357446
    Toni
    Re: Beko DWD8650 X
    Thanks Seamy
    Turned out to be main PCB
    As you say parts dirt cheap
    Toni
