Beko F/F CDA543FW
  • #80994
    robbra
    Everything in the fridge is freezing,and the freezer is ice clear.
    My question is, is the mini PCB on the control knob a stat or would it be the main PCB at fault?
    Any help welcome.
    Rob
    #415039
    Seamy
    Re: Beko F/F CDA543FW
    Mini p.c.b in fridge is the control only, if you look at the main board at back, one of the connections goes to an NTC in freezer section as far as I remember.
    Most likely on this one its a stuck relay though as if theres a faulty sensor the machine defaults to timed running of the compressor.
    #415040
    robbra
    Thanks for the info.
    Ordered a main PCB and fingers crossed.
    Rob
