Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Beko F/F Relay clicking compressor off??
- This topic has 10 replies, 5 voices, and was last updated 9 years, 1 month ago by
Nukeboy.
February 16, 2017 at 6:09 pm #90622
Nukeboy
ParticipantHello, My Beko F/F has stopped working. Compressor kicks in for 5 seconds then the relay or something clicks it off. This does it on a cycle every 3-4 mins.
Could it be the relay needs replacing.
Beko model is GENV220S
February 16, 2017 at 7:28 pm #445401Nukeboy
ParticipantRe: Beko F/F Relay clicking compressor off??
Pretty sure it is the PTC Relay
Beko PTC Relay 8EA 19E61 Is the part I need, but now they are no longer available. Anyone know of any alternatives that would fit my model?
This is what I need but can’t find one anywhere.
February 17, 2017 at 10:29 am #445402SAMURI
It is more likely to be the compressor faulty not a cheap repair.
Bob
February 19, 2017 at 4:32 pm #445403Nukeboy
Ok thanks.
I am hoping to try the cheaper route first by buying a Relay. Just cannot find a part that will fit
February 19, 2017 at 8:47 pm #445404SAMURI
If the compressor runs for a short time it will not be the relay.
If the relay was faulty it would not run or make any noise.
It runs for a short time then cuts out after a few seconds as the compressor is drawing too much current and then cuts out on the thermal cut out above the relay.
If you have a fault with the cut out or relay then the compressor will not run.
You can get universal relays but I would save your money as it will be the compressor faulty and if the new relay did work and run this would be short lived as it would weaken the thermal cut out and fail again.
You will find if you leave it on and it keeps running the compressor for a short time it will get Hot due to the windings overheating.
This shows it is getting power from the relay.
Bob
February 20, 2017 at 6:43 pm #445405Nukeboy
Ok many thanks for your Reply.
I think I will take your advice and buy a new compressor.
Are they Easy to fit by a reasonably mechanically minded
Person. I.e. Myself?February 20, 2017 at 9:59 pm #445406Lawrence
Nukeboy wrote:Are they Easy to fit by a reasonably mechanically minded Person. I.e. Myself?
In a word no, you would need to find a local refrigeration engineer .
It is a specialised job that requires specialised toolsFebruary 22, 2017 at 1:05 pm #445407Nukeboy
Ok thanks. I have been quoted £500. Does that’s sound about right?
June 15, 2017 at 11:17 pm #445408Neil1987
I need the exact relay for my beko fridge freezer!!! Did you find one? My compressor makes no noise at all when turned on all I here after five seconds of power is the relay click? Then the compressor just gets hot??? Is it the relay or the compressor
June 15, 2017 at 11:32 pm #445409kwatt
KeymasterRe: Beko F/F Relay clicking compressor off??
That sounds more like a compressor failure to be honest, it’s classic symptoms of that failed.
June 16, 2017 at 2:58 pm #445410Neil1987
Ffs! Not what I needed to hear, but appreciated, thanks for your reply
