Beko Fan Oven Element Wiring
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Beko Fan Oven Element Wiring
  • #7688
    Hi there, hope someone can help.
    I was replacing a fan oven element for a freind and took the element out to take to the shop to get the correct replacement, and took a note of the order of the wiring on a bit of paper for my reference when installing the new one.
    Unfortunately my freind lost the paper which I asked her to keep safe so I am unsure of which wire goes to which connection on the element!
    Does anyone know which order the wires go in – there is a brown wire, a green/yellow wire and a yellow wire, on the element there is a top and bottom connector and a centre earth connector.
    The oven is a Beko DCC4521w.
    Thanks in advance, Ronnie.
    #124691
    Dave_Conway
    Re: Beko Fan Oven Element Wiring
    The green/yellow lead is the earth, the other two don’t matter which way round they go 😉
    Make sure it’s disconnected from the supply !!
    Hope that helps.
    #124692
    ronk
    Thanks alot for the quick reply Dave, thats what I thought but I didn’t want to risk getting it wrong.
    Thanks again,
    Ronnie.
