beko fault code 6 any info please
Home Forums Public Support Forums Help And Support Washing Machine Help Forum beko fault code 6 any info please
  • #68428
    lushy0709
    Hi all,
    beko wma 641w
    I have been given this machine as my old one finally gave up.
    This machine was purchased new a few years ago put in my brother in laws flat and was never used (he gave his washing back to his mother to do) consequently I’ve now got it fitted it and it wont complete any program cycle, it fills drum turns once or twice then empties, if put on spin only drain pump spins drum turns once repeats twice then ends.
    I followed this
    http://www.ukwhitegoods.co.uk/help/fix- … codes.html
    and got code 6 Motor triac open circuit please can someone explain this or better tell me how to fix it.
    Many thanks in advance of any replies
    #371083
    jimca007
    Re: beko fault code 6 any info please
    The taco is the wee coil on the rear of the motor, a magnet attached to the motor shaft turns within the coil generating a small current, the faster it turns the higher the output this tells the machine how fast the motors turning.In your case this code would suggest the motor brushes are very low so the motor doesnt turn hence no generated current or alternatively there’s a wire broken on the motor plug. Unplug supply tilt the machine back to 45 degrees making sure it rests securely against a wall, then from underneath you can see the two black brush holders on the motor held on with two chrome star head screws remove one of the brushes and if the length is less than about half inch long you need to replace both. If not check the motor plug for broken wires giving each a GENTLE tug in turn to ensure none are broken.
    #371084
    lushy0709
    Thanks jimca007 you nailed it :worthy: :tup:
    It was a lose wire on motor I must have knocked it whilst moving it, by using a sack truck :boops:
    #371085
    jimca007
    Fantastic always nice to be right now and again ! 😉
