Beko freezer compressor in silence
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko freezer compressor in silence
  • #103611
    jack116
    My Beko freezer model FFP1671W has stopped working — the compressor won’t start at all; it’s completely silent. The evaporator fan also not working. The main power green indicator is on with red flashing and beep alarm indicating temperature high.
    It seems there’s no power going to the compressor however. I’ve checked the capacitor, relay, and PTC, EMI, and they all seem fine. The compressor itself also looks okay based on the resistance readings.
    The temperature sensor also appears to be fine. I’m wondering if the problem could be due to a PCB fault or a faulty temperature control keeping the freezer turned off. Is there any way to bypass the temperature control to test it? Also, is there a thermostat sealed behind the back panel that could possibly be preventing the freezer from running.
    #493947
    when you say temp sensor is fine
    how do you know ?
    jack116
    electrofix wrote: when you say temp sensor is fine
    how do you know ?
    I tested the resistance and auumes it is fine. The resistance is around 15K ohms at room temperature and around 20K ohms at minus10 degree.
    #493949
    jack116 wrote:
    I tested the resistance and assumes it is fine. The resistance is around 15K ohms at room temperature and around 20K ohms at minus10 degree.
    yes about right
    lists it as 15k should be 15 degrees and at 20k it should be 10 degrees
    if it was me I would swop the big blue capacitor and see what happens
    jack116
    electrofix wrote:
    yes about right
    Thanks Dave,
    no voltage to the blue capacitor when plugged sound issue with pcb or electricity cut off somewhere
    #493951
    ok power will come into the green resistor. this will then lead on to the capacitor
    you should get power somewhere in that area
    jack116
    If I short the triac transistor(btb16-800cw, the black one on silver metal, photo attached) the compressor and the fan start to work.
    #493953
    ok that proves the compressor
    measure the voltage across the blue capacitor
    also measure resistance on green resistor looks like 39 ohm
    jack116
    Dave[/QUOTE
    yes the resistance on the green resistor is around 39 ohm.
    Now the fridge freezer seems to work fine after PCB replaced, not exactly same model though
