Just wondered if anyone has knowledge of this freezer it seems to be working fine then the warning light comes on and the temperature starts to rise if you switch it off then back on again its ok then apparently
Think there was a batch of them with poor connection at the plug at rear, to side of compressor. Theres a plug pushing into a scoket in top of compressor cavity. From memory it was always the neutral that had a dodgy connection.
To be safe check all wiring to comp’, t’stat for loose connections.
