beko fridge freezer
Viewing 15 posts - 1 through 15 (of 18 total)
  • #7275
    challengedavid
    canyou help?
    i have a beko frigde freezer
    model cn 254 w
    serial 0210276811
    i just stays on all the time never stops
    i was thinking the thermosat has gone?
    any ideas
    thanks
    #122403
    Simon46
    Re: beko fridge freezer
    Does the fridge get very cold so it freezes the milk?
    #122404
    challengedavid
    it can freeze things if they are right at the back of the fridge
    otherwise things are very cold in there even if the contol is set to minimum
    #122405
    I think it’s stat reference B1-6169 – Dave Conway should be ableto source one for you.
    challengedavid
    thanks for the replys guys
    sorry for being a bit of a noob but dave conway how do i contact him
    regards
    #122407
    David,
    I believe that Dave is a tad hungover today. 😈
    But most likely he’ll be able to give you a definitive answer on his return to the office on Tuesday I think.
    challengedavid
    ahhh right i did not know who he was
    thanks for your help guys
    dave
    #122409
    Dave_Conway
    kwatt wrote:I believe that Dave is a tad hungover today.
    Only for part of the day, the trouble is it was the later part 😆
    I’ll check on Tuesday for you Dave 😀
    #122410
    Dave_Conway
    OK, part number 9002750200 is £27.49 inc VAT and delivery.
    If you’d like one ordered and sent on drop me an email to spares@ukwhitegoods.co.uk and I’ll arrange for you.
    #122411
    challengedavid
    hi dave
    thanks for sorting that out do you think that will sort the problem out ?
    if so i will have one i just don’t want to waste nearly £30
    regards
    Dave_Conway
    Without a diagnostic visit from a service engineer there’s no 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} way of telling to be honest, we can only advise on the possibilities.
    If you’re doing it yourself there’s only one way to find out, by replacing it and see 😉
    #122413
    challengedavid
    update
    replaced thermostat with new one still doing the same
    what next?
    #122414
    Assuming you have fitted it correctly, especially taking care with the capilary pipe and making sure it is fitted exacly as the old one was, its a system fault, Dave. Not easy to id. Basicly for whatever reason the frost line is never reaching where the end of the thermostat phial is hence the fridge keeps running.
    Expert attention required and its even possibly an unrepairable job but, being a Beko, get some quotes first.
    It was worth trying the stat though as it was a cheap option and would cure 9 out of 10 faults with your symptoms.
    #122415
    challengedavid
    i have just put a thermometer in it and it only cools down to 6degrees
    i have another fridge and it says 3 deegrees in there
    the fridge has been running for several hours none stop
    to me thats sound like i was wrong in the thermostat and maybe it needs regassing as its not getting cold enough
    is it a case of chucking it away?
    Dave_Conway
    challengedavid wrote:is it a case of chucking it away?
    Well, it’ll either be short of gas or the compressor has failed by the sounds of it.
    So, given the cost price of the Beko, economically it’s an unviable repair in my opinion.
    If you come to replace it,(don’t take this the wrong way as it’s meant as good advice) please don’t be drawn by the low price this time eh 😉
