beko fridge freezer
  • #81861
    eric.w
    Beko fridge freeze cda66ofw fridge not getting cold freezer not freezing foods i have replaced the Beko fridge freezer control board pcb at the back of it and still not working right i am going to replace the Fridge Freezer PCB Board Thermostat inside the fridge were the light is see if it is that the freezer fans running all the time and blowing cold air in the freezer the compressor ir running all the time its not cutting out can anyone advice me
    #417927
    stevebunyan
    Re: beko fridge freezer
    Has the freezer evaporator coil got an even coating of frost? or is it just frosty towards the top of the coil?
    If the later it sounds like it has lost some refrigerant and will struggle to get down to temp.
