Beko fridge freezer
  • #96402
    ghof
    I have a Beko fridge freezer model CDA539FW-2. What I can see is that the back of the fridge has a layer of ice and the fridge area is far too cold and freezes the food and drinks. The freezer is also very cold. Could you tell me which part I need to replace and advise on how to replace it?
    #463237
    bad new is as far as I know it will be a sensor problem. as with a lot of fridge freezers the sensor is attached to the evaporator before the foam is applied. to change the sensor involves digging a hole in the insulation while being careful not to damage the pipes. then installing a new one and re apply the insulation.
    plus you have to find a suitable NTC sensor
    all above is possible as other engineers have managed to find and fit suitable parts but its not easy. Beko don’t list a sensor on the parts list
    never tried myself as refrigeration is not my area of expertise but maybe other members will jump in and confirm
    Yup, it’s the sensor/s.
    digitalbob55
    Hi. Any info on how to actually replace the sensors?
    #463240
    as far as Beko are concerned its a write off (see my post above)
