Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › beko fridge freezer american style ap930x
- This topic has 16 replies, 6 voices, and was last updated 16 years, 3 months ago by
dealdd.
January 7, 2010 at 3:42 pm #51459
dealdd
Participanthas any one got a service manual or any paperwork for these machines first time i have come across them ???
January 7, 2010 at 8:48 pm #308131lerch
ParticipantRe: beko fridge freezer american style ap930x
Need a email address to send details!!
January 7, 2010 at 8:52 pm #308132lerch
Most common fault is that the wire on the ice maker breaks when is has been used due to wire being a bit on the short side.
Just remake and away you go.
January 8, 2010 at 10:30 am #308133dealdd
admin@dealdiscountdomestic.co.uk
the fault is the fridge gets to cold and also the door on the ice dispenser does not openJanuary 8, 2010 at 8:43 pm #308134cab
lerch do you have a service manual I posted last month for some info, I tried to get into the freezer compartment but could figure out how to remove the ice maker etc without breking anything which seems impossible on this machine
January 8, 2010 at 9:49 pm #308135lerch
Cab check your in box 😀
January 9, 2010 at 6:31 am #308136cab
Thanks will look it over later.
Cheers
January 11, 2010 at 2:09 pm #308137dealdd
cheers for that will arrange call to go back now and give self test a go. have you experianced one with the fridge getting too cold. it seems to be blowing colod air out the suction vent behind the salad bins not the top vent ???
January 13, 2010 at 1:18 pm #308138dealdd
turned out to be the circ fan in freezer and what a bugger it is to get too all plastic clips and screw heads that break. very cheep
January 21, 2010 at 9:17 am #308139funkyboogy
soory for hijaking post , we have a beko ff customer with same fault , ie to cold in bottom of fridge,
was in fan that caused problem …
cheers ally
January 21, 2010 at 10:57 am #308140dealdd
yes fan in freezer behind ice maker. back panel is a pain to get of as held in with pastic clips
January 21, 2010 at 8:38 pm #308141funkyboogy
cheers , sorry for sounding stupid – but how does a faulty fan in frz make fridge go to cold ???..
ally
January 22, 2010 at 10:33 am #308142dealdd
thought it was strange that the fridge still got cold with a broken fan. i found that only the salad bins were freezing stuff and the vent in the bottom was covered in ice. i will send you all the info i have on these units. whats your email address
January 22, 2010 at 5:44 pm #308143funkyboogy
cheers … email admin@atsscotland.co.uk
much apreciated cust a real pain in da arrrrrrrrrs
ally
January 23, 2010 at 9:36 am #308144bendaireboy
lerch is it poss for me to have same manual as i have same fault,thankyou
