Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › beko fridge freezer cda539fw
- This topic has 7 replies, 5 voices, and was last updated 11 years ago by
morrisbeko.
March 11, 2015 at 12:57 pm #84368
morrisbeko
ParticipantHi people need help! 😕 I have a beko fridge freezer cda539fw on the inside of the fridge, and on the back of the fridge it has a sticker with number cda539fw2 with is supposed to mean that my particular model does not have a removable thermostat wire so the main compartment on the fridge freezer is the pcb fridgefreezer control module board, on the back of the unit. my fridge compartment is still over freezing I have turned the knob inside the fridge to minimum but still overfreezes I have looked on forum and they changed the pcb board and now it works fine.. But not for me I’ve put a new one in that I brought from this uk whitegoods but still no change. in the fridge compartment I have the dail thermostat witch is set at min where the light compartment is. i have unscrewed it only to reveal small wiring. I have turned the dial thermostat while it was unscrewed and it seems to be turning something inside the parts that it’s attached to, it does feel quite loose when turning though but doesn’t look broken.. So I’m frustrated as to what to do next I need to get it right so I don’t spend too much money repairing it! As I have brought a board (pcb) that I don’t really need!! Please help!
March 11, 2015 at 2:18 pm #425479SAMURI
ParticipantRe: beko fridge freezer cda539fw
If the fridge rear wall inside the fridge is freezing evenly at the back and you have replaced the PCB.
The fault will be the sensor that is foamed in not a simple DIY job as you have to cut into the insulation.
If the fridge rear wall is freezing near the top and not evenly then it will be the compressor or a refrigerant fault also not a DIY job.
Bob
March 11, 2015 at 3:07 pm #425480morrisbeko
Thanks but ur breaking my heart!! Oh boy
March 11, 2015 at 3:12 pm #425481admin
KeymasterRe: beko fridge freezer cda539fw
He’s a typical bloke..always breaking peoples heart 😆 😆
Bryan
March 22, 2015 at 10:09 am #425482jskelton555
easy repair to change sensor under insulation at back of fridge, sensor is £9 off here and I even have video of how to replace. you have nothing to lose (well £9 really)
March 24, 2015 at 10:16 am #425483morrisbeko
Can you send us a link to your video thanks for info
March 28, 2015 at 7:58 pm #425484jskelton555
pm email address for video
April 13, 2015 at 8:56 am #425485mb547
Hi there.
I am new to the site. Having the same issue with my fridge freezing up. I have replaced the PCB with no change.Pretty sure i know where the sensor is to be replaced but i dont know the part number.
Would anyone be able to tell me what it is? and if possible the how to video.
Thanks for your help
martin
