Hi was wondering if anyone can help? hAVE A Beko CGA 966/963 and it’s buzzing from behind from a think the condensor?? When i swith it off and re start it, it stays quiet for a bit then starts up again, the fridge and freezer seem to work fine, and i have checked and can’t seem to find a fan (although i could be wrong).
Are the temp’s OK ?
The condenser is the black looking radiator thing connected to the back,they can be loose or pressed against the wall if the fridge is pushed too far back causing vibration.
Could be compressor noise,also there could be a refigerant relay but not sure on this model.
Not much you can do otherwise ,then it’s time for an engineer to take a look.
