Beko fridge/freezer control fault
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko fridge/freezer control fault
Viewing 1 post (of 1 total)
  • #12386
    marin_east
    Ive got a problem with my Beko fridge/freezer.
    The problem with it is, when the setting on the electronic control unit are
    set on any other setting except economy, the unit dosent hold its temp.
    If its set at the normal setting say 4degrees c, the fridge goes upto 8, and never comes back. But if its set at 5 (on economy) it will sit there and work ok.
    The problem started after the unit was moved, checked all conections on the p.c.b and on the stat/thermocouple. Think i need a new control board, but im unable to source one, i am an electrical engineer, so no problems with live tests etc…
    Model number CGA 9756 FFW
    Refridge type R 600a
    Charge 71g
    approx 3 years old.
    Any info/advice?
    Cheers
    Paul
