I inadvertainly left the fridge door of my Beko CDA751FS/1 open for how long i am not sure as it is outside in my shed. When i did find it a couple cans of coke had frozen and scattered their contents over the insides and the back panel was covered in about 1/2″ of frost like substance. I switched off the unit and left it to defrost for apron 36 hours. I switched it on again yesterday and left it for 24 hours. When i checked today the same symptoms were apparent. After reading through this forum i gather this unit has thermisters as opposed to thermostats. Is this the case?, and if so does anyone know the position of them as i gather they are buried in the foam at the back of the unit. Having looked at other posts for similar units are they likely to be buried in the same area i.e. could i use the pics and measurements from them units to locate them. Also I correct in thinking it should be the evaporator sensor that i am looking for and if so does anyone have a part number and cost of such unit. Many Thanks
