Hi, Can anyone help me with some tech advice, I have a Beko fridge freezer 4 years old, the fridge part won’t reach under 8 degrees which means my food keeps going off, the freezer part works fine at -16 so after some research I orders a new thermostat for it which my hubby fitted but it hasn’t changed anything, even when we put the temp dial to max it doesn’t improve go any lower than 8, I rang beko who suggested doing the thermostat and said if it’s not that it must be the compresser? But would the freezer work if the compresser had gone? And if it is that would it be worth fixing it, and would it be worth it? I really don’t want to have to buy a new fridge freezer as this one is in ex condition, apart from it not been quite cold enough!
The model number is CDA 563FS -2
Any help would be really appreciated
Thank you!
Jo x
