Beko fridge freezer issue
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko fridge freezer issue
  • #102941
    JAK68
    We have a Beko BCB7030F fridge freezer and the fridge has suddenly stopped working, the freezer is ok by the looks of it. Has anyone got any ideas what it can be? Thks
    #491158
    the very fact the freezer is still ok point to a possible ice build up in the freezer
    try a total defrost
    turn off , doors open, 2 days
    then turn on and see how it goes
    JAK68
    I have checked it properly this morning and the top of the fridge is a little bit cold but the bottom is room temperature, I have managed to get to the condenser coils inside the back of the freezer and there is no ice build up. So will go with a defrost to see how it goes..thks
    #491160
    if it does not work you need a new one
    there are 2 types of system
    older systems have 2 refrigerant coils . one in the fridge and another in the freezer. in this system the refigerant goes to freezer first and then goes onto the fridge. if the system is loosing refrigerant or the compresor is failing the fridge is the first thing to fail as there is not enough liquid refrigerant left to cool the fridge
    newer systems duct the cold air from the freezer and control this with a motorised flap . if the flap fails or ice blocks the ducts then the fridge stops working
    not sure which your system is but am thinking it may be the older one. in which case i would start looking to replace
    that means older type in the newer system only cold air through ducts goes to the fridge
    you also have no ice as you have already taken the freezer rear covers off
    from that i deduce you need a new one
    RachelInouye
    Blocked
    Thanks for answering.
