Beko Fridge Freezer Model No. CGA 9756 FFW
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko Fridge Freezer Model No. CGA 9756 FFW
  • #45194
    lousalo
    I wonder if anyone can help me. We have had the above fridge freezer for about 8 years? and in the last 6 months (ish), it has been collecting quite alot of water in the bottom, underneath the salad drawers. Does this mean it’s on it’s last legs?….I have tried to change the temperature on the fridge but it doesn’t seem to alter anything. It does NOT have ice in the back either, have double checked it. 😕
    #283977
    Specialist01269
    Re: Beko Fridge Freezer Model No. CGA 9756 FFW
    Does it have a drain hole in the rear of the cabinet to drain off moisture?
    If it does it’s possible that it’s simply blocked & not letting the moisture drain away & evaporate.
    Seen this happen a few times on different fridge freezers.
    #283978
    lousalo
    Thank you very much for your advice. I took out the bottom shelf and lo and behold there was mould in the drain hole! It’s all nice and clean now so hopefully it’s all resolved now. Thanks again.
