I have a Beko CF5834APS
The fridge part isn’t working. Freezer seems fine.
Compressor seems hot and the coils on the back of the fridge are hot to the touch in places (predominantly the pipe leading from the compressor up the rear side to the top of the coils)
Historically there has been a build up of ice on the back of the fridge. I researched it here and it sounded like a replacement thermistor was probably needed. However I left it and just chopped this ice away every now and then. It got worse recently with some items in the chiller draw freezing and alot of condensation gathering in the bottom of the fridge and freezing up.
The last couple of says the fridge seems warm and not working. Any suggestions as to whether my delay in addressing the freezing fridge has caused a more terminal problem with the compressor or if it might be thermistor related still. I’ve read about replacing the one behind the insulated back but if there’s no point now I’ll go straight to a new fridge freezer.
