I have a Beko TLDA662S fridge, recently the compressor has been on 24/7 and will never switch off, like it should do at times.As a result,it is using alot more power than it should do.The fridge makes gurgling noises quite frequently.The fridge is cold inside.
Things Ive tried so far:
Turned it off and on again at the plug.
Set the temperature dial to 2.
Cleaned the coil.
I am in the market for an efficient,reliable budget fridge freezer.It needs to be sized at least 75{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the size of my TLDA662s and be under £250.What brands should I be looking at and which ones should I stay clear of ?
