Re: Beko frost free fridge freezer
I guess it’s a bit late to help you on this but I have had a similar problem, the compressor and fan start up just after being plugged in then later fail to restart when they cycle off.
I found the supply voltage on the electrolytic capacitors on the PCB was down at 2.9 volts. the 1 uf dropper capacitor (Blue oblong thing) was down to 0.1 uf. As soon as it was replaced all worked as normal with 5 volts across the capacitors. This is the second freezer I have fixed with the same problem.
I will warn you, these boards are at mains potential, unless you know what you are doing you could kill yourself!
