Beko GL 32APB E0 fault code
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko GL 32APB E0 fault code
Viewing 1 post (of 1 total)
  • #85609
    lyncher1988
    I have a beko gl32apb that intermittently gives up an e0 fault code. The freezer defrosted once but has worked ok since. Temperatures in the fridge are around 6 degrees when the display is set to 4 degrees and the freezer is around -10 when set at -18. I understand it is a freezer sensor problem, but I am unable to find any freezer sensor listed in the spare parts. Anybody an idea about this fault?
