Beko GNE480E20FX American Fridge Freezer E13 Fault
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko GNE480E20FX American Fridge Freezer E13 Fault
  • #102775
    jay fray
    I have an Beko GNE480E20FX American Fridge Freezer, purchased in 2020.
    It first displayed an e13 error about 1 month ago, the fan would pulse on for about 2 seconds then stop for about 4-5 seconds, then repeat
    When this first happened, we removed the drawers to look for obvious reasons and found that the right-hand side freezer unit had ice build-up behind the rear panel. We removed the ice and when powered back on, it was still in fault mode. The fault resolved itself after about 15-20 minutes.
    Today the E13 error started again. No obstructions and again the fan pulsing as mentioned above. I understand the compressor is located on the left-hand side panel and normally this is warm to touch. Today whilst in fault mode, the external side wall was lukewarm. I could also hear a click every time the fan started or stopped, can’t say for sure, sounded like a car relay.
    I turned the power off for a few minutes and the fault continued for about 15 minutes. Suddenly the fault stopped again…. itself. The side wall is now warm as normal.
    Your help and input is much appreciated
    #490416
    error is listed as freezer fan error
    jay fray
    Hi Dave
    Thanks for your reply
    the first time this happened, it was the right side compartment with ice build up
    today it’s the left side compartment fan pulsing
    would you say both fans might be faulty
    thanks
    #490418
    this is how the faults are listed
    jay fray
    Thanks Dave
    Does this normally mean the actual fan is at fault or maybe another component the fan might plug in to
    what document did you find that table?
    thanks
    #490420
    found table in the service manual
    and yes it could be fan, wiring or board and that the hard bit
    its take a gues and buy a part time
    jay fray
    Does the service manual give details of testing the components? Eg resistance of fan etc
    also there is a service mode on these, how can I access this and what each code means
    thanks
    #490422
    there is no info on testing the motor
    there is a test mode but i dont think it will give you any more info than you have which is a fault code
    its one of those faults where you have to fit the part to find out if its faulty
