Product No: 7293443781
Serial No: 17-101196-10
Hi all
Is there any technical info available on these units please?
I have been to see one where I think that either the compressor or the inverter module is faulty but not sure if or how I can narrow down which it is. The unit is only just keeping temperature but it seems like every couple of minutes that it will run the compressor for 5 or 10 seconds before it shuts off again, the compressor does have a slight bit more noise than I would have expected but it doesn’t seem to be locked and the compressor case temperature is only 60 degrees so I was wondering if anyone knew what the chances are of it being a module fault.
Thank you
Jem
